What part is this?
Noticed this was cracked while changing my valve cover gasket today...
What are those two hard lines? What is the one with the crack and what is that piece? Could I pick it up at the dealership?
Thanks
that is $40 at the dealer and you can get it cheaper on line, but that MUST be throwing a code like p0411. use hose clamps to secure. get the part number off of it because they can't easily find it in the catalog without the part number.
That's the tube between the SAI pump and the combi valve. Doesn't get hot from the air in it, but it does sit right above the turbo. Heater hose would work if you need to pass inspection or somethin but it wouldn't last very long. I'd tear all that **** out completely if you have the option.
pretty sure I have one in the garage, my work ordered one and ended up not needing it and the Audi dealer would not return it. Shoot me a PM or email at derzeck@me.com
It's part of the secondary air injection system. The SAI pump sucks in clean air, pumps it through the tube you took a picture of and into the combi valve on the back of the cylinder head. This supposedly improves emissions on cold starts. In some of the united states, it's illegal to remove this kind of stuff because of emissions inspections. Do you have emissions inspections in your province?
DiscoJaker
Dec 2, 2020 02:16 AM
pzp107
Apr 21, 2014 06:27 AM
vwjetta4me
Nov 2, 2007 12:51 PM
bartvaio
Aug 27, 2007 11:46 PM
