What's the best 1.8T engine?
Old Apr 1, 2013 | 01:05 AM
  #51
Mike-2ptzero's Avatar
Originally Posted by meloman
If you're gonna replace all that then why not spend the extra couple hundred and go 2.0?
It is more then that since there is more work to put in a 2 liter crank into a 058 block.
Old Apr 1, 2013 | 01:26 AM
  #52
meloman's Avatar
Good call, I thought we were talking about an 06A still
Old Apr 1, 2013 | 11:23 AM
  #53
FishEye's Avatar
If I buy a 99' b5 a4 1.8t off Craigslist for around 1400$ how would I check if its the 06a block?
Old Apr 1, 2013 | 12:03 PM
  #54
Mad Cow's Avatar
It's not, only the AWM is an 06A so it was only available in '01. You could in theory use a MK4 1.8t block because they were all 06A or 06B, but you'll still need a B5 AWM parts car for all the stuff you'll need to swap over. Look into passats too, quite a few get parted out and overlooked.
Old Apr 2, 2013 | 11:28 AM
  #55
FishEye's Avatar
Are all the connectors and sensors the same on the passats and mk4s? Like for example if i couldnt find a certain sensor or wire on the donor a4 or donor passat can i pull it off a mk4 ? And the 06A can handle more power than the aeb? I'm kinda not sure about what to go with here... An aeb or a awm. Also what year passat has the 06A? 01 also? Sorry for all the questions I'm just really trying to get all the facts straight before I purchase a donor car / motor..
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
