Whining noise?
Old Oct 17, 2008 | 08:00 PM
Stevenw83's Avatar
Member
Default Whining noise?
I have a manual 97 2.8 quattro. Recently i have noticed a whining noise that comes and goes when i shift. When i increase in rpm's it gets higher and as i shift the whining noise sounds decreases as the rpm goes back down. Does anyone have any ideas what this could be? Also since this started to occur the check engine light had come on.
Thank You
Old Oct 17, 2008 | 08:54 PM
A4speed's Avatar
its probably best that you go to autozone, borrow the scan tool, put the codes up on here and then we can further help you out!
Old Oct 18, 2008 | 09:02 AM
Isramirez21's Avatar
Where does the whining noise come from?
Old Oct 18, 2008 | 01:38 PM
Stevenw83's Avatar
Member
it sounds to me and i may be wrong, but under the driver's side hood by the fire wall...
Old Oct 20, 2009 | 02:40 PM
Stevenw83's Avatar
Member
here when my clutch was replaced the abs sensor was knocked out of place and that was what was causing the noises that i heard.
Sean1234
Jun 25, 2014 10:50 PM
NICKV
Mar 23, 2013 12:46 PM
gregshu
Dec 21, 2012 06:37 PM
vlado182000
Jan 23, 2011 06:57 PM
shady927
Jun 4, 2008 01:58 PM
