Will 225/50/18 fit on a 2001 A4?
Old Jun 1, 2008 | 10:43 AM
blk340cuda's Avatar
Default Will 225/50/18 fit on a 2001 A4?
Looking to buy a set of 18 rims and I want to fita big tire on them. I'd rather not put on a 40, as a 50 will give me more sidewall. Has anyone ever put a 50 on their car or does everyone just stay with the 40.
I’m probably going with the ASA RS1s (black with machined lips). Is there anything I should be aware of? I have read that they are a soft rim, which is kind of why I want a bigger tire. Any help is appreciated.
Thanks, Mike.
Old Jun 1, 2008 | 10:49 AM
hiwords's Avatar
Default RE: Will 225/50/18 fit on a 2001 A4?
i don't think 50 fits. 45 with rolled fenders should i believe. also depends on how much you lowered your car
Old Jun 1, 2008 | 12:23 PM
ImTheDevil's Avatar
I'm running 40-series tires (225-40-18) on a lipped rim, and I haven't had any trouble. I am vigilant about dodging potholes and the like, which certainly helps. Remember two things here - one, a low-profile tire has more reinforcement in the sidewalls to help protect against wheel damage, and you also typically run a little higher tire pressure on lower tires (on my OEM 16" tires - 205-55-16) I ran 36-38psi, but on these I run about 40psi. Second, if you run a 225-50-18, you're going to completely screw up your speedometer/odometer calibration. At 60mph indicated speed, your actual road speed is 64.2mph, a difference of 7.1%. Your odometer will be messed up by a corresponding percentage. It's up to you if you want to deal with that and constantly be calculating your actual speed based on indicated speed - especially when a surprise speed trap pops up in front of you.
Old Jun 1, 2008 | 02:39 PM
jibberific's Avatar
^^^ what he said, i run the same size tire at about 36 psi, and i roll right over most imperfections in the road. besides, a sidewall that big on 18's will look like crap. like a funny cartoon car almost. i wouldn't do it.
Old Jun 2, 2008 | 06:21 PM
Tweaked's Avatar
ORIGINAL: blk340cuda
Looking to buy a set of 18 rims and I want to fit a big tire on them.
Thanks, Mike.
Why would you do this? Your tach will be way off and your Quattro, if so equipped, may take a beating. Oversized tires are not recommended for street cars.
ASA rims aren't just soft, they are sometimes not even true from the factory. Spend more money on better quality rims or go with 17"s if you are concerned about ride quality or wheel damage.
Old Jun 2, 2008 | 07:25 PM
AteUrV8's Avatar
a 55 will fit if you dont lower it. If you lower it than it will be hell, but like mentioned about why would you want a 55 profile tire?? get a 40 profile.
I have 225 40 18 and im lowered 2.5" in front and 2.25" in back and i rub sometimes in the front but never in the back
Old Jun 2, 2008 | 07:41 PM
Bogie's Avatar
Thanks, Mike.
If you want more sidewall, then don't buy 18's. Go with 17's and get 225/45/17 tires.There's still plenty of sidewall there. 18'sareoverrated for performance, and are more for looks in myopinion.
Old Jun 2, 2008 | 08:27 PM
ImTheDevil's Avatar
I had 17x7.5 wheels before my current 18s, and ran S4-sizing (235-45-17). It was a nice look, with enough sidewall to absorb some of the bumps that I feel on my 18s.
Wtftylor
Nov 1, 2012 01:01 PM
klipsch21
Jul 27, 2010 08:41 PM
Euthanasia
Feb 22, 2008 01:30 PM
Jorgen
Jul 29, 2006 02:25 PM
Bit646
May 11, 2006 05:24 AM
