windsheild washer fluid warning
Old Aug 30, 2012 | 09:13 PM
Davidiot's Avatar
Originally Posted by o_a_ravi@hotmail.com
I had this problem too.
Issue 1: Headlight Washer pump rusted and leaking
Issue 2: Reservoir was cracked and leaking.
Replaced the washer pump. And repaired the bottle using JB Weld epoxy.
Epoxy did not fix the leak and is still leaking, the water stays to the level below the water sensor, causing the Washer Fluid warning to go off. With the annoying beep.
FIX: I might replace the bottle in the future, but to fix the warning/beep for now, I just used a 1K Resistor from the local radioshack and inserted in to the sensor wire connectors. (between the 2 wire terminals).
This actually tricks the ECU to think that the Sensor is not open and the water level is OK.
very helpful and useful post thank you very much
Old Aug 31, 2012 | 12:31 PM
jonbonesjones's Avatar
Moderator
if needed. i have a full spare washer systems pump and all. I think i still have the tank somewhere also.
Old Sep 1, 2012 | 11:33 AM
o_a_ravi@hotmail.com's Avatar
I would be interested in taking the bottle/reservoir. Could yoy please check and email me the pics and details ?
The bottle on mine is the one with 2 pumps for windshield and headlight washers.
Old Sep 1, 2012 | 02:43 PM
Moderator
ill go look. mine is the 2 pump unit as well. Going digging for it now.
Old Apr 13, 2015 | 09:25 PM
markkuhn's Avatar
Default windshield washer bottle leak: headlight pump
Do you have to remove the tank to get the headlight washer pump out, or can you reach in and remove it with the tank in place?
Old Apr 16, 2015 | 10:56 AM
Mark C's Avatar
What year car do you have, my 01 a4 Avant quattro has a separate level sensor about 1/2 way up the tank, on the engine side, plus 2 washer pumps down near the bottom, one for the windsheild/headlight sprayers, and one for the rear glass which is about 2 inches higher up the tank than the windsheild pump. All three penetrations into the tank have gaskets around them and if the pump, or sensor isn't mounted into the tank right they leak like pigs. The one around my sensor leaks so the washer fluid drains down just enough to keep the damn light on.
As far as removing the pump, you have to remove the inner fender liner, and then you can reach around the bottom of the tank and pull it out. you will of course loose any water in the tank, so don't be laying under it when you pull it out of the tank. The body of the pump just passes thru a rubber donut like gasket so it will pull striaght out, no twisting required. Depending on how rusty you electrical connector is, the whole top half of the pump might pull apart when you try do get the connector off. Be careful when disconnecting that connector.
Old Apr 16, 2015 | 11:37 AM
markkuhn's Avatar
I have a 2003 Allroad. I'm not sure if I can reach the lower pump without removing the tank from the car. Does the pump just pull out, assuming I can reach it past all of the other stuff?
quattrojoe
Sep 11, 2012 01:02 AM
Cnap10
Sep 14, 2010 08:01 PM
ckbkny
Aug 28, 2009 04:04 PM
smurph1080
Jul 18, 2009 10:55 PM
Waidesworld
Nov 6, 2007 01:09 PM
