Wipers problem
Old Jan 14, 2013 | 07:27 AM
Sn1p3r's Avatar
Default Wipers problem
Hello!
Old problem came back again, last time it fixed by itself, now it started again, but much more annoying.
Whenever I turn ignition on (not starting the car) wiper starts to wipe, but they are working in some wierd interval, and it stops in middle. I start them again, and again it stops little closer to their default position, I start them once more then they stop where they should.
and now when I turn key to start the car, again wipers starts to wipe.
When I put my lever in position to wipe > pause couple of seconds > wipe, they stops normal, make a pause and start again, but when I put lever in "Off" position they start to wipe with that wierd interval.
Help!
Old Jan 14, 2013 | 09:56 AM
ImTheDevil's Avatar
Sounds like the stalk is corroded/dirty/otherwise failing. Pull it and clean it up and see if it starts acting right.
Old Jan 14, 2013 | 02:11 PM
Sn1p3r's Avatar
Restarted ECU (by unplugging battery for 45mins), tried still same, and the moment I started driving everything is back to normal.
Now is ok
Old Jan 15, 2013 | 07:02 PM
Slowb5's Avatar
wierd, intermittent. defintately a corroded terminal somewhere, id say source a wiring diagram and check for green fuzzy stuff. perhaps, anything installed recently?
Old Jan 16, 2013 | 07:36 AM
Sn1p3r's Avatar
this problem occured half year ago... but it fixed itself after couple of days.
I think the problem is in lever... when I shake it a bit in all directions it stops them.
vettemad
Aug 1, 2009 04:23 PM
aublutiger
B7 Models
Jun 9, 2008 04:33 PM
duburban
Dec 11, 2007 10:11 PM
jac
Dec 4, 2006 11:50 PM
freddjoh
Mar 28, 2006 09:33 AM
