Would this be legal?
Old Aug 21, 2009 | 10:52 AM
yuriy's Avatar
Default Would this be legal?
Im thinking of doing my own DIY intake, the tutorial can be seen here, but i heard that it might not be legal use a breather filter in an application like that. The breather is on a pipe that leads to the secondary air pump. Would you still be able to pass emission with that?
Edit: I had the air pump mixed up with the PVC valve so i think it should be fine to run that setup, but i would still appreciate some feedback regarding this topic. Thanks.
Old Aug 21, 2009 | 11:07 AM
hiwords's Avatar
yes you will pass.
Old Aug 21, 2009 | 11:36 AM
AutoUnionFan's Avatar
i've never heard of any real performance change, only a change in sound, but the one guy with the auto said his car stopped downshifting after the mod
i think the best setup would be a custom heat shield with the stock duct running from the grill through the heat shield to the filter, like the one guy did except the ducting that runs to the bottom of the car is probably overkill
Old Aug 21, 2009 | 12:50 PM
Jackmup's Avatar
That is exactly how my 3.0 and 4.2 are set up from factory the MAF is in line with the air box. I don't use those K/N filters though. OEM for me.
Old Aug 21, 2009 | 01:47 PM
yuriy's Avatar
Sweet! Thanks for the info guys, appreciate it. Ill give it a go later on today if i find both filters. Ill just have the stock ducts running to the filter, should be more than sufficient. Ill update and tell you if i notice any changes.
Old Aug 21, 2009 | 01:56 PM
make sure you take some pics
Old Aug 21, 2009 | 02:51 PM
audi guru's Avatar
there will be very little change because all b5s already have sufficient airflow going to the engine. all it will do is sound. maybe i little bit of difference. i got maybe 5 horse at most. it was very little, but it does sound really cool now
Mr. Phil
Feb 28, 2010 06:44 PM
corwin06
Jan 27, 2010 03:56 PM
jhlax57
B7 Models
Nov 16, 2009 05:41 AM
Mass
Oct 29, 2005 04:27 PM
