'03 A4 Xenon Ignitor
Old Jan 16, 2013 | 12:46 PM
pa4ul's Avatar
hmm not sure if u can actually replace that socket. U would have to replace the whole housing. let me ask you this question. When the bulb goes out do the high beams work and does the turn signal work?
Old Nov 10, 2013 | 10:41 AM
ghughes3.gh's Avatar
Default head light is driving me crazy
2003 a6 driver headlight work sometimes thought it could be bulb. so I took bulb and put it in passenger side and it worked fine so I put bulb from passenger side in driver side then it worked so I turn car off put light back in. turned back on driver side didn't work wtf. please someone help this is my first audi
Old Nov 11, 2013 | 10:09 AM
ayobowan's Avatar
Had the same problem. Tried everything to avoid a new headlight ($1600/Audi). New Light switch, ballast, bulbs, socket, wire testing etc. All a waste of time and money; so I bought a used headlight on eBay and the problem was solved. Turned out it was the ignitor (that's the part the sockets is wired to) within the headlight case, Can't be bought separately at Audi. Some guys sell them on the internet, but you would need to crack open the headlight case to get the old one out and the new one in. Not worth it. Buy a used headlight.
Old Nov 11, 2013 | 11:10 AM
Jeff-AudiUSAParts's Avatar
Former Sponsor
Ghughes3, For an 03 a6 with the V6 the drivers side ignitor is available, and for your car is part number 4Z7-941-471 and costs 614.80 retail and is 457.41 dollars website price. I realize that is still an expensive part and a used headlight would be the most economical way to go. Some useful info for you would be that the ignitor is different from left to right side lights, and the v8 A6's use a different part number on the ignitor, headlight part numbers are different as well but I don't know in what way they are different. I only see the part numbers. The 02-04 V6 A6 and 01-05 allroads share the same ignitor, so if you find a used headlight and ONLY want the ignitor you can widen your search by including allroads.
Old Dec 30, 2022 | 01:06 PM
ChrisTurry's Avatar
Default СпаÑибо, долго иÑкал
очень интереÑно, но ничего толкового
_________________
sport jonli VK uchun prognoz - firibgarlar futbol bashoratlari / biz bilan faqat bukmekerlar qizil rangda
Old Jan 4, 2023 | 03:42 PM
clayquint's Avatar
I ordered ballast from ebay for about $23 for 2005 a4 b6 with early vin# ***039212. For D1S low beams, H7 highs. All three bulbs are out ...haven't installed new ballast yet.
Old Aug 25, 2024 | 12:39 PM
PercivalShortz's Avatar
The dealer is going to charge you about $125.00 for the new bulb (that includes the ignitor) The other part to the xenon system is the ballast. The dealer wants about $650.00 for this part which is out of control. Of course this is the part that I had to replace.
silveraudib6
Feb 25, 2014 12:43 PM
mb2audi
Dec 8, 2010 11:45 PM
Bearz54Urlacher
Dec 28, 2009 10:57 PM
PSU02A4
Jan 29, 2008 09:07 AM
megslade1
Jan 21, 2008 06:53 PM
