2002 a4 CVT shift cable mount to trans case won't line up after removing Valve body.
I had to remove the TCM again for a faulty speed sensor so while it was out getting repaired I removed the valve body to replace the speed rings and check the solenoids. I've removed the TCM before and it all went back together without a problem and ran good for 30k miles. The only thing I did different was remove the VB. Well, after putting it all back together I find out the shifter mount to trans case won't line up unless I put the car in Drive. I bolt it up thinking i'm good, go to put her in park and it won't budge from drive. The little brown spring loaded elbow piece was put back on the same way it came off. What could I have done wrong? The cable mount just won't reach the holes on the case..
Thanks, Jim
Thanks, Jim
I had to remove the TCM again for a faulty speed sensor so while it was out getting repaired I removed the valve body to replace the speed rings and check the solenoids. I've removed the TCM before and it all went back together without a problem and ran good for 30k miles. The only thing I did different was remove the VB. Well, after putting it all back together I find out the shifter mount to trans case won't line up unless I put the car in Drive. I bolt it up thinking i'm good, go to put her in park and it won't budge from drive. The little brown spring loaded elbow piece was put back on the same way it came off. What could I have done wrong? The cable mount just won't reach the holes on the case..Thanks, Jim
