2003 A4 1.8T Engine Issue
Old Jun 10, 2010 | 07:39 PM
mitch603's Avatar
Default 2003 A4 1.8T Engine Issue
So as of yesterday my car started to rap/knock very loudly at about 2900-5000k RPM. It really only does it if im slowly going up in RPM's. If i stomp on it then it barely happens. MY oil pressure is not low im topped off perfectly. But im not very fond of this sound. HELPPPP MEEE
Old Jun 14, 2010 | 12:26 PM
primo382's Avatar
Was the engine overheated at any point?
Try to isolate the location of the sound using a screwdriver, piece of broom handle, bearing stethoscope... etc.
Not sure how common it is on these vehicles but water pumps can make a metallic clunking knocking sound when the bushing fails. Given the track record of the 1.8T water pumps, maybe someone could weigh in as to the sound their pump makes when the impeller splits.
Old Jun 15, 2010 | 03:49 PM
R.A.I. Motorsport's Avatar
Former Sponsor
You need to scan the car for codes first, that will give you a starting point.
mbruecher
Feb 21, 2015 06:23 PM
chucknastyy
Feb 16, 2013 11:35 PM
mattfort
Nov 15, 2010 07:30 AM
slizkovach
Jul 9, 2008 12:03 PM
rketekt
Jan 20, 2007 01:12 AM
