2004 A4 1.8T Quattro engine temp
Old Jun 14, 2012 | 11:07 AM
wilkslda's Avatar
Default 2004 A4 1.8T Quattro engine temp
Hi fellows,
I have 2004 A4 1.8T Quattro. I have some questions about my engine temp needle
position. When I drive around 30m/h, the needle position is right at the
middle. When I enter interstate and the speed goes to 60m/h, then the needle
quickly moves to 3/4 quarter position, and there is a beeper and dashboard has
"coolant" flashing, the needle continues to pass 3/4 position and gets close
to "H". So I have to slow the car down. What would be the likely cause?
Thanks a lot!
Old Jun 14, 2012 | 11:20 AM
brrman's Avatar
Low on coolant?
Leaky head gasket is also typical. Is your oil frothy? Or is your coolant sludgy and discolored?
Other possibilities, bad coolant temp sensor, stuck thermostat, bad waterpump, clogged radiator, or dead radiator fan.
Old Jun 14, 2012 | 03:33 PM
wilkslda's Avatar
just changed oil. added some coolant fluid (color is all right). Took it to a friend, he said could be thermostat.
Originally Posted by brrman
Low on coolant?
Old Jun 14, 2012 | 03:46 PM
brrman's Avatar
yeah if the thermostat is sticking closed (or open but not enough) it is not letting enough coolant through the system to be effective when you are driving faster/higher rpm.
Old Jun 14, 2012 | 05:47 PM
pa4ul's Avatar
i say u got clogged up! Do a flush and see how things go.
Old Jun 16, 2012 | 11:24 PM
fire5414's Avatar
Hope it's the thermostat, that's the first thing I replaced when my old audi started overheating...it didn't fix it. It was the water pump, the impeller wasn't broken but the bearing was shot. You could spin the gear but it wouldn't spin the impeller. That was a fun couple of days.
1337patch
Sep 15, 2012 07:04 PM
DJ Martinii
Mar 20, 2008 04:50 PM
jankerfun
Nov 12, 2007 01:47 PM
bloodshot
Nov 25, 2006 06:45 PM
