Advice on turbos please
Old Jan 12, 2012 | 05:10 PM
Evil02B6's Avatar
Default Advice on turbos please
Hey guys I'm new to turbos and I am wondering what I can do to produce a louder turbo whistle and blow off noise. I've heard about doing a cone filter but I feel like the stock air box is well designed and no need to change that. So help me out pleaseeeeee thanks
Old Jan 12, 2012 | 05:23 PM
02A6Beau's Avatar
the audi turbo system is not designed to "whistle" or "blow-off". just leave it alone
Old Jan 12, 2012 | 05:28 PM
Evil02B6's Avatar
Uhh thanks...
Old Jan 12, 2012 | 06:15 PM
turbo kraut's Avatar
Tech Guru
Swiss cheese your airbox or cone filter will make your turbo louder. And a better diverter valve will give more of a whoosh noise. Don't do a bov if your stock.
Old Jan 13, 2012 | 08:54 AM
Evil02B6's Avatar
OK thanks you for the advice man, I appreciate it. Now I'm assuming what you mean by swiss cheese, is drill holes in my airbox. And I know enough not to put a blow off in place of a diverter valve. Haha
Old Jan 13, 2012 | 09:20 AM
02A6Beau's Avatar
do a search for "swiss cheese mod" and you will see how different people have done it, but yeah, basically you drill holes in your air box. make sure you keep everything under the filter. there are few different things you can do to keep larger debris and water from getting in.
Old Jan 13, 2012 | 09:36 PM
Audi Tek's Avatar
Tech Certified
The turbo is well designed too. You can either vent to atmosphere..... "blow off" or "Re-circulate".
Blow off is counter performance..... the only purpose is to make a noise.
Audi has a factory re-circulation system / diverter valve
Old Jan 16, 2012 | 05:41 PM
pa4ul's Avatar
if u swiss cheese ur box make sure u remove all the sound deadening material from inside. And get a k&n high flow filter. U can also get a forge splitter where u can adjust how much is vented to atmosphere. . . .
quattroforthewin
Oct 6, 2010 08:51 AM
speedys4
Jan 17, 2010 11:32 AM
the A6 guy
Jan 24, 2008 12:42 PM
funtoy138
Dec 24, 2006 03:50 PM
meat
Nov 5, 2006 06:04 AM
