Aftermarket Stero rear speaker / amp Humming issues
Hi Everyone,
I see there are many issues on here regarding aftermarket steros but couldnt find one relating to my problem, so here goes...
recently bought a 2003 (B6) A4 130SE and would like to replace the symphony (non bose) radio with a new one so i can use my Ipod anyway bought an ALPINE CDE-W203Ri and fitted it got the rear speakers and everthing working ok using the PC9-401, thei noticed this quite loud hum from the rear speakers and also a high pitched noise coning from the rear offside door speaker??? was told that it may be a bad ground but when i asked my local car audion store they said that the stereo would already be grounded through the audi harness and that it might just be that the head unit is not compatible with the car??... anyway after much messing about i returned the stero for refund but am now unsure what to do... was looking at the Clarion CX609E but will i get the same problem again? anybody had this problem? any advice would be greatly received
Cheers in advance
Cheers in advance
Is the PC9-401 an adaptor for the symphony stereo to add an ipod? Have you tried removing this to see if there is a change? It does kinda sound like a bad ground from what you've mentioned.
I've never heard of a stereo not being compatable with a car, maybe the harness. I would contact Alpine directly or Crutchfield and explain the issues you are having. Crutchfield has great customer support.
The headunit should be grounded through the harness, so no additional ground should be required assuming you have the correct harness for the car. I say grounding issue because that's usually that would cause a hum. I am only familiar with the Bose system. I'd still say Alpine or Crutchfield are your best sourches for a solution.
A4 2000
07-15-2012 06:07 AM
