Ashtray
I've got a 2002 A4 3.0 manual transmission, and on that car I believe I did have to remove the ac unit and the radio to remove the ashtray. The ashtray is held down by two hex head bolts. To get at these bolts I used my fingers to pull up on and unclip the wood trim piece around the gear shifter.
I did not use any tools, and would not recommend using any. Open up the ashtray cover and grab and lift the trim piece from the ashtray end. The trim piece is held on by 4 or so metal clips. If you haven't removed the trim piece before, those clips are probably still holding it down relatively tight.
