Ashtray
Old Oct 22, 2011 | 03:39 PM
LateBloomer11's Avatar
Default Ashtray
How do i take out the front ashtray of my audi a4 2002 3.0L V6. Is there any way to do it without having to remove the radio head and the ac unit.
Old Oct 25, 2011 | 07:28 PM
JDJ's Avatar
JDJ
I've got a 2002 A4 3.0 manual transmission, and on that car I believe I did have to remove the ac unit and the radio to remove the ashtray. The ashtray is held down by two hex head bolts. To get at these bolts I used my fingers to pull up on and unclip the wood trim piece around the gear shifter.
Old Oct 26, 2011 | 09:40 AM
Default Ashtray
I tried that and it sounded like it was going to break i don't want to pull it all the way up and snap it off. Did you use a screwdriver or anything.
Old Oct 26, 2011 | 03:19 PM
JDJ's Avatar
JDJ
I did not use any tools, and would not recommend using any. Open up the ashtray cover and grab and lift the trim piece from the ashtray end. The trim piece is held on by 4 or so metal clips. If you haven't removed the trim piece before, those clips are probably still holding it down relatively tight.
Old Oct 27, 2011 | 12:05 PM
pa4ul's Avatar
i learned that most of the panels in our cars require a good amount of force while removing. If it sounds like its breaking u are probably doing it the right way.
B6 Cabrio
Oct 23, 2009 03:06 PM
nfoman
B7 Models
Sep 20, 2009 09:50 PM
godfatha2120
Oct 15, 2008 04:13 PM
acamillo
Feb 5, 2008 11:51 AM
Bass402
May 25, 2007 04:00 PM
