Burning Oil in Exhaust and need help fast
If the smoke is blue then it looks like oil is getting into the combustion chamber. Many reasons for that, but none are good. Start by doing a compression test and verify all cylinders are good and then take it from there. There is also the possibility that the turbo broke.
Just did a compression test and got good results.
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
This should rule out some things, but i also found oil in my coolant reservoir. coolant looks dark red brownish. So somehow oil is mixing with my coolant.
anyone has any ideas as to what could be causing this?
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
how often do you have to top up on oil?
Did the car overheat?
How many miles on th car?
CCJ
Jun 11, 2013 11:39 PM
