Burning Oil in Exhaust and need help fast
Old Aug 8, 2012 | 10:25 PM
ajp02a4's Avatar
Default Burning Oil in Exhaust and need help fast
I have a 2002 A4 1.8T Stock.
I'm burning oil (fast) in the exhaust with no noticeable leaks causing it to smoke and feeling a little power loss.
Whats the problem???
Old Aug 9, 2012 | 12:15 AM
z28pete's Avatar
Is the smoke coming from inside the exhaust pipe or from around the outside of the pipe?
Old Aug 9, 2012 | 10:38 AM
ajp02a4's Avatar
It's coming from inside the pipes, going out the mufflers...
smokes from just turning on the car to driving around.
any ideas as to what it could be?
Old Aug 9, 2012 | 11:57 AM
z28pete's Avatar
If the smoke is blue then it looks like oil is getting into the combustion chamber. Many reasons for that, but none are good. Start by doing a compression test and verify all cylinders are good and then take it from there. There is also the possibility that the turbo broke.
Old Aug 9, 2012 | 02:31 PM
ajp02a4's Avatar
Yea thats what i was thinking as well. Okay anyway my friend is lending me his compression tester and i will do it asap.
hopefully this will scope out the problem..thanks a lot for your help!
Old Aug 10, 2012 | 07:09 PM
ajp02a4's Avatar
Just did a compression test and got good results.
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
This should rule out some things, but i also found oil in my coolant reservoir. coolant looks dark red brownish. So somehow oil is mixing with my coolant.
anyone has any ideas as to what could be causing this?
Old Aug 20, 2012 | 05:08 PM
MagA4's Avatar
cyl 1- 180
cyl 2- 185
cyl 3- 180
cyl 4- 187
Looks like your head gasket's gone buddy
how often do you have to top up on oil?
Did the car overheat?
How many miles on th car?
Old Aug 26, 2012 | 12:46 AM
ajp02a4's Avatar
It was the turbo went so i had to get a new one sucked but now the cars runs so much better
thanks for the help
tnorm077
Mar 30, 2013 02:37 AM
LiMe101
Apr 16, 2012 03:51 PM
Kandy Orange Z
Apr 11, 2012 06:30 PM
atheros
Aug 18, 2008 12:57 PM
