Cam tensioner gasket.
those things go out randomly.... .. i know its a pain in the ***.
i would check all of your fuses... again.
and maybe reset your ecu?!
are you grounding the coil when looking for spark?
it shouldnt be losing spark. but i have started alot of sentances about my car with ' IT SHOULDNT BE.........'
i dont think there is any way to test the crank sensor either..
do a little searching on crank sensors
ecu reset :
disconnect battery
disconnect ECU
reconnect battery
turn key to on... make sure you have NO check engine light. you shouldnt. the car isnt recognizing its not running
turn key off.
disconnect battery
reconnect ecu
reconnect battery
start your car
vuala... done
disconnect battery
disconnect ECU
reconnect battery
turn key off.
disconnect battery
reconnect ecu
reconnect battery
start your car
vuala... done
robert.jones
Dec 10, 2008 08:01 AM
robert.jones
Dec 10, 2008 07:56 AM
