Changed Oil Sensor and light is still on... HELP!
Old Aug 25, 2011 | 04:44 PM
dahaze's Avatar
Default Changed Oil Sensor and light is still on... HELP!
I have a solid yellow oil level sensor on my dash. I changed the sensor and cleaned the connections and I still have the yellow oil sensor display. Shouldnt this have reset itself if the problem was fixed...? So if its still on what could possibly be the problem?
Old Aug 25, 2011 | 06:02 PM
pa4ul's Avatar
u need to chain or top off your oil? if its yellow that is. If its red then u might have a bigger problem.
Old Aug 25, 2011 | 07:44 PM
dahaze's Avatar
its solid yellow, i changed the oil today when i put the new sensor in. i checked the dipstick it has the correct amount of oil in the motor.
Old Aug 26, 2011 | 11:23 AM
pa4ul's Avatar
okay it says oil sensor and not min oil right. I would examine the wires to make sure they arent chewed up or something.
Old Sep 5, 2011 | 12:37 PM
dunanga's Avatar
If the wiring and oil level are both ok, did you clear the fault using VAG/VCDS?
If you did not try that first before any titreing.
Old Sep 13, 2011 | 06:49 PM
dahaze's Avatar
I have the simple ecu detector thing. I plug it in and it shows me the check engine lights, I have all of them cleared and it still showing up in yellow
Old Sep 14, 2011 | 06:30 AM
dunanga's Avatar
Use VCDS and clear the DTC.
Old Sep 14, 2011 | 11:39 AM
nkasco's Avatar
the pump might be shot too. i have an 03 1.8t and the oil on the HUD kept coming on after an oil change and i reset the service and everything, eventually it went away after like a week, though i did try to secure the sensor a little better so it might have just been dirty/loose.
make sure the o-ring on the sensor is seated properly too
Crimson1221
Sep 29, 2007 11:03 AM
jdrz
Sep 10, 2007 01:25 AM
ecksman
Mar 29, 2006 03:20 AM
