Clear Fluid?
Old Jan 7, 2010 | 12:17 AM
gschleg84's Avatar
Default Clear Fluid?
I am noticing a clear fluid that is leaking from my car. I notice some wet spots on the driveway when I move my car in the morning. The leak seems to be on the drivers side between the motor and the coolant reservoir. It is toward the back of the engine about six inches from the fire wall. Could someone inform me what this leak could be? The fluid is clear and has a slippery, lubrication type of texture. I started noticing this leak about a week ago which is when the temperature around here started staying at around 20-25 degrees. Maybe a hose cracked? I would appreciate any input. Thanks!
Old Jan 7, 2010 | 12:48 AM
shane.trammell's Avatar
clutch, brake, power steering??
Old Jan 7, 2010 | 08:52 AM
gschleg84's Avatar
We can rule out clutch, because I have an auto. I guess it could be either brake or power steering fluid. Do these fluids have any color to them? I know where the brake fluid resevoir is. Where is the power steering filler cap located at?
Old Jan 7, 2010 | 10:47 AM
They are both clear. The power steering is just behind the drivers headlight. Green cap and the steering rack is a common problem.
Old Jan 7, 2010 | 10:30 PM
scskim's Avatar
either way, a clear oil leak isn't good. get it checked out asap
teddysart
Jul 7, 2011 11:16 PM
MartinCieslak1
Feb 25, 2011 07:51 AM
a88fl1
Jun 28, 2007 04:50 PM
