Coil Packs!
How often are you supposed to change coil packs? I have a 2004 A4 1.8T with 93,000 miles and had the tune up done I think at 70K but don't know if the coil packs were changed. Engine was running hard so I changed the plugs with NGK iridiums but no change. How do I know if it is 1 or all 4? since they are about $25/ coil pack I would like not to have to buy all at once? please help.
Search!!!
You dont need to change them unless they fail. Or if u just want to upgrade them to the new R (revision) coilpacks.
If ur engine is shaking (misfiring) any time your car is on- than most likely your coilpack(s) is blown + CEL. Otherwise might be a vacuum leak/ bad gap for the spark plugs.
Do u have a CEL?
To find out which coilpack is bad:
car is on, take the first one out, if there is no change than you found it, if your car starts shaking even more- than it is a good coilpack.
))You dont need to change them unless they fail. Or if u just want to upgrade them to the new R (revision) coilpacks.
Do u have a CEL?
drft1
Jul 5, 2010 12:19 PM
kraylon
Jul 29, 2009 12:19 AM
