Coil Packs!
Old Nov 3, 2008 | 06:27 PM
Appleby3's Avatar
Default Coil Packs!
How often are you supposed to change coil packs? I have a 2004 A4 1.8T with 93,000 miles and had the tune up done I think at 70K but don't know if the coil packs were changed. Engine was running hard so I changed the plugs with NGK iridiums but no change. How do I know if it is 1 or all 4? since they are about $25/ coil pack I would like not to have to buy all at once? please help.
Old Nov 3, 2008 | 08:57 PM
audiprotein's Avatar
Search!!! ))
You dont need to change them unless they fail. Or if u just want to upgrade them to the new R (revision) coilpacks.
If ur engine is shaking (misfiring) any time your car is on- than most likely your coilpack(s) is blown + CEL. Otherwise might be a vacuum leak/ bad gap for the spark plugs.
Do u have a CEL?
To find out which coilpack is bad:
car is on, take the first one out, if there is no change than you found it, if your car starts shaking even more- than it is a good coilpack.
Old Nov 3, 2008 | 09:42 PM
R3K8C24's Avatar
Sorry for this dumb question, but I have no idea about coil packs. Where is it located and is it easy to change em out for a guy like me that has very little knowledge about the engine and such? Thanks
Old Nov 3, 2008 | 11:27 PM
ignition coilpacks located on top of the sparkplugs
Old Nov 4, 2008 | 11:19 AM
Appleby3's Avatar
Default Coil Packs
Thanks for replying AudiProtein. This helps much. My CEL is on. I will check them one by one.
Old Nov 4, 2008 | 11:47 AM
kwik_shift's Avatar
always carry a couple in the trunk, you never know when they are gonna blow. Last thing you want is to be stranded on the highway.
Old Nov 4, 2008 | 02:49 PM
If your cel is on, but your car drives ok than 99% your coilpacks are ok. Everytime they go out, you car starts misfiring A LOT.
drft1
Jul 5, 2010 12:19 PM
audiquattroa4
May 6, 2010 04:40 PM
kraylon
Jul 29, 2009 12:19 AM
Apdl
Jul 8, 2008 06:25 PM
boy412
Jul 24, 2007 04:09 PM
