coolant/power steering fluid
Old Nov 29, 2011 | 08:02 PM
Freddddddddddyy's Avatar
Default coolant/power steering fluid
Hello, I just got my first Audi, (2004 A4 1.8t) so I'm slightly clueless on some of the simple things, and I'm not much of a gear head, but anyway I know it calls for specific coolant, but is it ok to use the "any make and model" fluid? since supposedly it can be added to any type, or do I need to hunt down the "g12" fluid if that's what its called. On that same note I noticed my power steering fluid is quite low. Is there a certain type I need to use for that too?
Sorry if it's a dumb question I just want to make sure I use the right stuff
Old Nov 29, 2011 | 10:29 PM
JPracing's Avatar
You must have G12 u can get it on line or at a dealer.
Old Nov 29, 2011 | 11:48 PM
ImTheDevil's Avatar
Use G12 coolant and Pentosin CHF-11S power steering fluid. You cannot mix PS fluid with anything else. Buy at the dealer or order online.
Old Nov 30, 2011 | 11:28 AM
jdahlen24's Avatar
One caveat to watch out for on the coolant. If the current coolant is green in color, don't add G12 to it. Mixing regular old green coolant with the special Audi G12 coolant will turn your coolant into ugly brown/orange paste, which is not good.
So, just make sure that the current coolant is pink, and you'll be fine adding the G12 in.
Old Dec 1, 2011 | 04:43 PM
Thank you for your help!
Old Dec 2, 2011 | 04:34 AM
BlackRingedB6's Avatar
Napa carries CHF-11S power steering fluid for $22. Not sure what the dealer charges for that stuff.
jibberific
Mar 13, 2008 04:23 PM
jamespayne
Mar 7, 2008 05:05 PM
thrax982
Mar 31, 2005 10:15 PM
CaliA4
Mar 31, 2005 01:28 AM
