Drive Belt
Hello all. I started noticing my drive belt squealing a bit after startup. What is the procedure to check, tighten and or replace it? Maybe one of your guys has a PDF from the manual?? I have 46k on my A4. I am thinking maybe tightening the belt would do the trick since my mileage is fairly low.
Rick
Rick
Wd-40 is not a lubricant, it's actually a cleaner, but it could help. The timing belt tensionser is a different part than the accessory belt tensioner. The acc belt tensioner is the one you can see, the other you can't.
