Drive Belt
Old Mar 30, 2009 | 02:06 PM
rick_me24's Avatar
Default Drive Belt
Hello all. I started noticing my drive belt squealing a bit after startup. What is the procedure to check, tighten and or replace it? Maybe one of your guys has a PDF from the manual?? I have 46k on my A4. I am thinking maybe tightening the belt would do the trick since my mileage is fairly low.
Rick
Old Mar 30, 2009 | 03:15 PM
shane.trammell's Avatar
There's no way to tighten it. There is a tensioner on the belt that goes bad. You could try workin the tensioner, or spraying some lube on the tensioner pulley.
Old Mar 31, 2009 | 09:56 AM
rick_me24's Avatar
Yeah I'll spray some WD on it. Too early to replace the belt and/or tensioner. It's not bad yet. I just noticed it one day and thought maybe I could tighten it.
Thanks for advice.
Old Mar 31, 2009 | 11:31 AM
Wd-40 is not a lubricant, it's actually a cleaner, but it could help. The timing belt tensionser is a different part than the accessory belt tensioner. The acc belt tensioner is the one you can see, the other you can't.
phatjames167
Feb 11, 2013 10:06 PM
Novis11
Dec 21, 2010 11:21 AM
bvoltzke
Jan 18, 2010 11:02 PM
stabgotham
Sep 5, 2009 01:11 PM
Midniteoyl
Apr 15, 2009 07:28 PM
