EPC light came on and can't start the engine
Old Nov 18, 2011 | 12:20 PM
kayooh's Avatar
Originally Posted by jinsojoo
Here's a link to instructions on how to replace your engine speed sensor....
:: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
Can anyone tell me the location of this part on a V6 3L engine?
Would the part # be the same as in this thread?
Thank you all.
Old Oct 31, 2015 | 06:08 PM
jibril_s's Avatar
My Audi A7 is doing the same thing. Won't start and displaying the ECP light. Now the service engine light is on also.
It died on my while I was driving and displayed maximum RPM reached (Thursday evening). Then it wouldn't start. I had it towed to Volkswagen that night and the next morning they cleared the codes and the car cranked on the first try, so they couldn't duplicate the issue. I drove it home and it wouldn't start again that night. It cranked Saturday morning and I drove it to Volkswagen again and the service guy said I needed to take it to Audi. I drove it back home but made a stop and it wouldn't crank again. After about 4 hours and 3 tries, it cranked again. Now it's here at home and I'm planning to get it towed to Audi (50 miles away) on Monday. I'll let you all know what they say and I'll definitely suggest the speed sensor.
Dash Display
https://www.dropbox.com/s/uzfrnwicqv...26.06.jpg?dl=0
Video of starting
https://www.dropbox.com/s/ihd6i1o0kc...26.20.mp4?dl=0
Old Oct 31, 2015 | 06:51 PM
jibril_s's Avatar
https://www.openbay.com/crankshaft-p...i-a7/dallas-tx
Crankshaft Position Sensor Replacement
What does the crankshaft position sensor do?
The crankshaft position sensor monitors the rotation of the crankshaft, specifically targeting when the number one piston reaches top dead center (TDC) in the cylinder. Most crankshaft sensors are mounted just above a notched ring on the crankshaft or above the flywheel. These sensors use a magnet to produce or vary an AC electronic signal that is used in conjunction with a camshaft position sensor to determine when a position approaches top dead center (TDC) on the compression stroke. In modern engines, with advances in variable valve timing and direct injection, the crankshaft position sensor is the most important input for the on board computer.
What are the symptoms of a faulty crankshaft position sensor?
Simply stated, the car will not run. Until the on board computer receives a signal from the crankshaft sensor, there will be no spark and the engine will not start. Moreover, when the on board computer receives an erratic signal, internal logic will understand this as a mechanical problem, and it will shut down the engine to prevent any damage. The engine will stall out for no apparent reason. Heat, age and especially rust are the biggest culprits for sensor failure.
What is the severity of a faulty crankshaft position sensor?
The failure of a crankshaft position sensor could leave you stranded on the side of the road waiting for the tow truck. Sometimes, if the sensor is allowed to cool off, the car may restart and run for a short period. Before getting to the turn and pray approach, find a good mechanic, one who specializes in engine performance, and set an appointment. Plan on dropping off the car for up to several days as some sensors make take longer than others depending on exact location.
What is the typical cost to replace a crankshaft position sensor?
Estimated part(s) cost = $50- $100
Estimated labor cost = $600- $700
Estimated total cost = $650 - $800
This will be a repair of two extremes - cheap or expensive. The sensor will cost somewhere between $50 and $100 depending on the manufacturer. However, installation can really vary depending upon the car, and in some cases run upwards of $600 to $700 or more. Many sensors will mount on the engine or insert through a hole in the engine near the crankshaft pulley, which is much easy to access. Other sensors will mount inside the timing cover or inside the transmission bell housing, and are very hard to access. These parts will need to be removed in order to access the sensor. Incidentals, including gaskets, may run an extra $50 to $100 dollars.
Again, pricing will vary by location and your vehicle make and model. Save time and money by using Openbay to compare pricing and book an appointment with a service center in your area.
Service article written by an ASE Master Technician
If you want this service performed, Openbay can help get qualified automotive service professionals to perform the work for you.
Old Jan 5, 2023 | 06:22 PM
Bnuss25's Avatar
Default A4 crankshaft wire connector
I had similar problems and code came up as the crankshaft position sensor. When I replaced the sensor and was try to pull the wire connector apart I pulled the wires out. I bought a replacement connector but both wires are black and the wires from the car colored. Do they need to be in a certain order? This sensor only has two wires
Old Jul 6, 2024 | 12:59 PM
PercivalShortz's Avatar
To change the sensor you don't have to even get under the car (but if you do it will be easier) there is the water reservoar on the right topside in the engine comp. that the bolt that holds it out and lift the reservouar away to the right (there is a sensor under it to be removed) lower a mirror near your oil filter and you will see the crank sensor near to the right of the oil filter hold in place with one screw. Unscrew it follow the wire to the firewall and unplug it replace it. put everything back and enjoy your $60 repair.
AZMSP84
Jun 12, 2021 05:15 AM
IvDogg
Apr 3, 2019 11:24 PM
cabofixe
Aug 18, 2012 10:17 AM
tdepirro
May 24, 2012 03:02 PM
y2karnival
Apr 12, 2006 01:42 AM
