Faulty Windows
Old Mar 29, 2013 | 08:35 AM
meikle's Avatar
Default Faulty Windows
Hi all,
Recently I've had an intermitant fault with my electric windows, sometmes they would work but now they just won't work. I've checked the fuse box but all seems fine, I've also seen on the web that there's a 'Circuit Breaker@ but can't find where it is, If anyone has had similar problems or know a fix I'd be very much appretiative.
A4 1.8T Quatro 2002
Thanks
Colin
Old Mar 29, 2013 | 09:10 AM
ilackav8's Avatar
usually its the window switch.a quick replacement should fix you up.
Old Mar 29, 2013 | 11:28 AM
meikle's Avatar
Hi,
But the other side don't work either + I checked the mirrors & their out as well :,-(
Old Mar 29, 2013 | 02:56 PM
ilackav8's Avatar
do the windows work normally when you use the switches on their respective doors, or do they just not work from the master control on the drivers door?
Old Apr 1, 2013 | 10:22 AM
meikle's Avatar
Hi,
They dont work on either door
Teyssere
Oct 3, 2013 03:45 PM
swifty2712
Mar 9, 2012 02:07 AM
striker451
Sep 4, 2009 03:44 PM
powman
Apr 24, 2007 02:35 PM
jl365
Jan 2, 2006 04:09 PM
