Full Heat even when set to cold - servo motor fault
Heater flap control wasn't working. I've seen many videos on how to fix this and most people seem to buy a new unit rather than repairing the servo motor itself. It is very easy to repair:
1: Remove glove box (approx 8 screws and its out)
2: With ignition on move each of your controls to see which servo motor is not responding - easy to spot each one moving
3: Disconnect electrical plug on the suspect servo motor
4: Remove the 3 screws holding the servo motor in place and disconnect the actuator arm
5: Open up the servo motor by pushing the tabs out with a fine blade
6: Check the attached photo - you can remove the little motor and two cogs easily
7: Clean them up and use some silicone lubricant
8: Put it back together and test with either a 12v bench supply or plug it back in the car
One word of caution, make sure you either mark or take a photo of the original position of the rotation arm before disassembly....
Servo motor actuator arm
Opened up showing two cogs and potentiometer
Close up view showing motor fully and cogs.
Pawel123
01-29-2006 05:36 PM
