Help Front rotor removal
2003 A4 1.8
ok I removed the caliper and caliper bracket. Anything else i need to remove? Or do i just need to wack the old rotor off?
Many thanks
O
Many thanks
O
R6 Euortuner Brake removal
Here is the link and text below:
This should get everybody through and make sure you get two 13mm wrenches or you will not get the calipers off. Audi makes this area hard to work in. I picked up one thin 13mm and one socket-wrench 13mm for faster bolt removal. Do this or you will be here for a bit getten the damn bolts out.
http://www.eurotuner.com/techarticle.../photo_53.html
HOW-TO: Change 2.7T Rear Rotors/Pads
________________________________________
Ok guys, I spent some real time searching the forums to see if anyone had posted a "how-to" on changing rotors/pads that included pics, descriptions, etc. I did not come across one good one that helped me. So here is mine, after figuring out things on my own :-) I hope this helps others, time & money, at the dealership. I know how much our A6's love to eat rotors/pads and so it is much easier to know how to DIY!
First things first, get all of the parts you will need. (See pic 1 & 2)
- New Rotors & Pads [OEM @ Dealership - Total $163 w/tax [REAR ONLY]
- Car jack with jack stands (Ramps will NOT work)
- Impact Gun with an 11/16 Impact Socket (to remove wheel)
- 13mm Socket with Ratchett and Ratchett extension
- 8mm Allen Wrench
- Rubber Mallot
- Clamp [Metal/wood clamp] (Forgot to take pic of! Sorry)
- One hour or so of your time
Ok, now that you have your parts, you're ready to begin:
Start by removing the wheel using your impact gun so you can gain access to the caliper, old pads, and rotor. The first thing you need to do is remove two 13mm bolts holding your caliper onto the rotor.
(Pic #3)
There is one on top and one on the bottom towards the ground. For this, I found I had to use a wrench (not the 8mm Allen) to hold the inside bolt of the caliper still, while I loosened the 13mm bolt.
The next step was to remove the caliper carrier from the wheel hub by undoing the two 8mm allen bolts. There's limited clearance so take care. Nothing holds the rotor in place except rust. Be careful it doesn't fall on your toes but hit it with a mallet to loosen it form the hub. Then take a wire brush to the hub so the new rotor can sit flush.
Once those two bolts are removed, your caliper is now "free/loose." However, it's still going to be sitting pretty tight. Use your rubber mallot with a little bit of force to knock the caliper off of the old pads/rotor, hitting it towards the rear-end of the car.
Remove your old pads.
At this point, you are to the point of photo #4 (only with the old rotor). Now you may or may not have to remove the rotor bracket (Pic #4). On my driver side, I did. My passanger side I was able to just slip the old rotor out, wiggiling it around, and the new one in. If you have to remove this bracket: This is where your 8mm Allen Wrench comes into play. Looking closely at the back of this bracket you will see two allen bolts holding it onto the rotor. Place your 8mm allen wrench in the bolt, and using your rubber mallot, hit the allen wrench a few times until it becomes loose enough for you to loosen by yourself (they are TIGHT). Once the bracket is removed, remove the rotor (if your rotors are extremely rusty, again, you may have to give the rotor a few taps from behind to knock it loose (with the mallot of course).
Almost there! Now time for re-assembly!
Place your new rotor on to the wheel assembly, lining up bolt holes. [If removed] replace your rotor bracket and re-tighten the allen wrench bolts. Place your new pads on the rotor bracket as show in Pic #5.
Now pause. Before putting your caliper back in place, you need to use your clamp to squeeze the piston of the caliper back in. Without doing this, the caliper will never fit over the new pads.
Once the piston is pushed all the way back in, replace your caliper over the new pads. Re-tighten your 13mm caliper bolts; place your wheel back on, lining up the wheel holes, with the rotors' holes, to the wheel assembly holes; Grab your Impact gun, tighten all bolts (Doing opposite sides at a time); Lower your car and you're done! Wha-laa :-)
I hope this was helpful to those who need it. Ask any questions.
- 8mm Allen Wrench
- Rubber Mallot
(Pic #3)
