Help with rear rotor removal - 03 A4 1.8TQ
Old Nov 8, 2008 | 11:27 AM
aloo's Avatar
Default Help with rear rotor removal - 03 A4 1.8TQ
Does anyone out there know if its possible to remove the rear rotors on an 03 A4 1.8TQ without removing the caliper carrier bracket? The head on one of the bolts on my bracket is stripped, so short of cutting the bolt out, I have not way of getting the rotor out. Any help is appreciated.
Old Nov 11, 2008 | 06:12 AM
patchelect's Avatar
Simple answer-
NO! The carrier must be removed first.
Old Nov 11, 2008 | 07:14 PM
Darkprodo's Avatar
Originally Posted by patchelect
Simple answer-
Simple response to simple answer -
YES!
if you can remove one of the bolts and have a pry bar. you can move the carrier out of the way enough to get the caliper in and out
Old Nov 11, 2008 | 10:07 PM
aloo's Avatar
Default Thanks for the replies
Thanks very much for the replies. I took it in to a local shop and they were able to get the bolts out and replace them with new ones. Funny thing, I had to try two differnet dealers to get the new carrier bolts. The first dealer insisted that I needed to buy the entire carrier for an extra $117 per side.
B5bretheren
Jun 8, 2014 12:10 AM
f_g_garcia
May 17, 2009 10:38 PM
omanalansan
May 17, 2009 06:56 PM
paul.cadima@ge.com
Oct 19, 2008 06:49 PM
ein Silbern A4
Oct 16, 2006 05:19 PM
