help with rear brakes
I need to replace the rear brake pads and rotors and I cannot for the life of me get the bolts that hold the carrier on off. I have done this job on two other A4's, a B6 and a B5, never had an issue but I cannot for the life of me break those bolts free on any side. The car is a 2004, but with less than 60k miles so I am assuming they are original pads.
Does anybody have any tricks on how to break them free? I tried a pipe, soaked them in PB blaster, but still no luck.
TIA
TIA
Have same problem on A6 2.7T front. Friend said to try a very very small torch on the bolts. He also recommended putting a lot of wet towls around the area. He said the heat should un-lock, freez the bolts. Have to buy new rubbers or maybe bolts. I HAVE NOT TRY THIS YET, on my Audi, but need to solve tire problem yet. Could also try a air-compressor if not tried yet. the bolts turn counter-clock. I had no problems with my rear brakes (bolts). changed them pretty easy.
