help with rear brakes
Old Nov 30, 2012 | 09:12 PM
steelman93's Avatar
Default help with rear brakes
I need to replace the rear brake pads and rotors and I cannot for the life of me get the bolts that hold the carrier on off. I have done this job on two other A4's, a B6 and a B5, never had an issue but I cannot for the life of me break those bolts free on any side. The car is a 2004, but with less than 60k miles so I am assuming they are original pads.
Does anybody have any tricks on how to break them free? I tried a pipe, soaked them in PB blaster, but still no luck.
TIA
Old Dec 1, 2012 | 12:04 AM
Retiredglock40's Avatar
Have same problem on A6 2.7T front. Friend said to try a very very small torch on the bolts. He also recommended putting a lot of wet towls around the area. He said the heat should un-lock, freez the bolts. Have to buy new rubbers or maybe bolts. I HAVE NOT TRY THIS YET, on my Audi, but need to solve tire problem yet. Could also try a air-compressor if not tried yet. the bolts turn counter-clock. I had no problems with my rear brakes (bolts). changed them pretty easy.
Old Dec 1, 2012 | 12:55 AM
Dan1969's Avatar
PB blaster and an impact gun. I did that on my B6. Heating is a good way but chances are you will need to rebuild your caliper and probably change your brake hoses after you're done.
Old Dec 1, 2012 | 01:18 AM
Dan1969 is probable right. One has to be extremly careful not to damage something else.
Old Dec 3, 2012 | 10:04 PM
johnwiz's Avatar
I haven't done this on my A4 yet, but on my Vette I used a breaker bar with a 3 foot piece of pipe over it to break them free. Just needed a little bit of movement to get them started.
A4tun81
Feb 25, 2010 10:02 AM
tha_grouch
Nov 26, 2007 08:04 PM
mkunert
May 12, 2007 10:14 PM
onepoint8tee
Jan 3, 2006 05:35 PM
elwolfe
Aug 30, 2005 05:54 PM
