i need help with my problem
My lighting for inside the car like when the doors are open do not work anymore.....also when i lock my car with the remote it doesn't make the beep noise......i'm pretty sure i blew a fuse but i am not sure which one or number of fuse it is....so if you have any info that will help me that would be great Thanks
Yup its a blown fuse. The fuse is located by the driver side door. Close to the door hinges, remove the panel and look for the blown fuse. I've had to replace this once but I forgot the name that's under. Let us know if you have any other questions.
on the other side of the panel that you take out has the numbers that correspond to each fuse. take that number and use your owners manual to figure out which one goes to what.
i think thats how it is. my car is in that shop still so its something like that.
