i need help with my problem
Old Jan 31, 2009 | 04:15 AM
2003 audi a4's Avatar
Member
Question i need help with my problem
My lighting for inside the car like when the doors are open do not work anymore.....also when i lock my car with the remote it doesn't make the beep noise......i'm pretty sure i blew a fuse but i am not sure which one or number of fuse it is....so if you have any info that will help me that would be great Thanks
Old Jan 31, 2009 | 11:25 AM
kwik_shift's Avatar
Yup its a blown fuse. The fuse is located by the driver side door. Close to the door hinges, remove the panel and look for the blown fuse. I've had to replace this once but I forgot the name that's under. Let us know if you have any other questions.
Old Feb 7, 2009 | 12:29 AM
Mattazaudi's Avatar
if you can get a test light from a friend just probe the tops off all the fuses, one side then the other, if both sides of the fuse are the same (+ + or - -) the fuse is good if they are opposite (+ -) then its blown..
Old Feb 7, 2009 | 09:59 PM
bennybiggs's Avatar
on the other side of the panel that you take out has the numbers that correspond to each fuse. take that number and use your owners manual to figure out which one goes to what.
i think thats how it is. my car is in that shop still so its something like that.
Old Feb 8, 2009 | 04:07 AM
Member
yeah it was just a fuse....problem solved thanks for the help!
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
