LCD / Display replacement on Symphony II Radio
Old Nov 9, 2009 | 08:17 PM
jinsojoo's Avatar
Default LCD / Display replacement on Symphony II Radio
I have the Audi Symphony II with missing lines on the radio LCD / display. I also have an extra Symphony II, which is a little rough around the edges, but the display works perfectly fine. However, I was not given the code the unit when it was given to me.
Has anyone taken apart a Symphony II to replace the LCD / display? I would like to swap the displays in my two units.
Is going to the dealership or car stereo shop the only way to retrieve unlock codes?
Thanks in advance for any tips.
Old Nov 9, 2009 | 10:28 PM
Dan1969's Avatar
No, I haven't really heard of that, I'm sure someone somewhere tried it. The best way I know of to fix that is to find a good condition one and replace the whole radio.
Old Nov 10, 2009 | 05:03 PM
jinsojoo's Avatar
Well, I solved the problem...
I went ahead just switch the displays between the two units. In fact, all I had to do was remove 2 screws on each side of the faceplate and swap the faceplates (which contained the LCD / display)
Anyhow, I hope this helps anyone out there someday ;-)
Old Nov 19, 2009 | 01:47 PM
mani's Avatar
Guys,
I have the exact same problem. I got few thick lines on the Symphony display. I like to get it changed. Does anyone know where can I get a replacement display from?
Thanks!
Old Nov 20, 2009 | 04:49 PM
jinsojoo's Avatar
If I were you, I would find a cheap used one. Even if the seller doesn't have the code and if the unit doesn't work, as long as the display works, you can swap it with yours. That's what I did. Maybe try www.car-part.com.
The swap is actually very easy. I did it in about 20 minutes.
Good luck!
Old Nov 20, 2009 | 08:35 PM
mani's Avatar
Thanks jinsojoo....
I picked up a Symphony II unit from wrecked car. The unit is in excellent shape.
Do I have to pull out the entire unit off the dashboard to swap the displays? I would greatly appreciate any tips on it from your experience.
Old Nov 21, 2009 | 01:30 AM
jinsojoo's Avatar
I think it would be easiest if you just call me. I can walk u through it.
415 706 2106
Old Nov 21, 2009 | 10:21 AM
mani's Avatar
Thanks man. I will call you soon after I get the DIN removal tool.
Old Nov 21, 2009 | 05:48 PM
mani's Avatar
jinsojoo - Thanks very much for your help with it.... I got the LCD display changed in no time...
The new display is very nice.
You guys rock!
amiddle104
Jul 21, 2010 04:14 PM
davempt
Nov 5, 2006 07:33 AM
davempt
Nov 1, 2006 02:00 AM
AdLucem
Jul 10, 2006 07:45 AM
