Looking for OEM Clutch Kit
Old Oct 18, 2010 | 12:13 PM
BrianVarick's Avatar
Default Looking for OEM Clutch Kit
I need to replace my clutch and I am having a mechanic do it who wants to make a little money on the side. I am supposed to supply the parts though. Is there a kit somewhere that has everything I will need, or will I only know when he gets in there. Looking at ecstuning under oem, they have a lot of little parts, but I don't know what all I need. A little help would be very much appreciated
Old Oct 18, 2010 | 04:29 PM
Mike-2ptzero's Avatar
If you are replacing just the clutch the stock flywheel will need to be resurfaced and checked for play. You also want to replace the flywheel bolts, pressure plate bolts and the throw-out bearing. On most clutch kits the TB is included, but the bolts are not. If you go with a clutch/flywheel package everything should be included.
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
