Lowering 2002 quattro 1.8t wagon
Old Dec 29, 2013 | 06:31 PM
20021.8t's Avatar
Default Lowering 2002 quattro 1.8t wagon
I just posted this in a suspension thread but thought it might get more views here.
I've recently decided that I want to lower my car on adjustable suspension. At the moment I've got 20x8.5 wheels. the tyres rub sometimes but only at higher speeds with weight in the back. Theres a carpet like lining above the wheels which it might just be rubbing on, I think its a protector for flying stones etc. I was told you could "roll the guards" and this might help, also because I want to get wider 9.5inch wheels in the near future. Could someone please tell me what the best way to go about this is? Also, an irritating shudder would occur when I reached speeds of over 70-80kmh. I got a mechanic to look at this and they couldn't find anything wrong, but as soon as I got the car back a feint squeeking noise would appear when going slow. as days rolled by it got worse and now when going slow enough and turning the wheel left, it turns into a clunking type noise. Any ideas?
Old Dec 31, 2013 | 04:19 PM
20021.8t's Avatar
help help help
Old Jan 2, 2014 | 05:01 PM
ex56TT's Avatar
Banned
i stuck these on to help the front wheels at least, im running 19's tho not 20s
SPC 81350 Audi B5, B6, B7, C5, and VW B5 Adjustable Front Control Arms!
*** GROUP BUY PRICING IS IN EFFECT --- SET OF 4 --- LIMITED AVAILABILITY ***
As many of you have found out, when lowering your suspension, camber and toe become misaligned which leads to expensive tire wear and poor handling. Since the OEM has made no provisions for lowering the vehicle, there is no adjustment that can be made to bring the wheels back into alignment on a lowered vehicle.
SPC has released this Set of 4 adjustable front upper control arms which will allow +/- 1.5 degrees Camber and/or Caster change for these vehicles. These arms directly replace factory fixed-length arms, allowing easy adjustments after installation. Engineered for both street and track use, forged 6061-T6 aluminum ends with large 18mm threaded adjuster links assure this is the strongest kit available. Maintenance free ball joints and bushings provide factory ride, handling, and NVH performance.
Click here to see the installation video :
These come as a SET OF 4 and fit the following models :
Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
Audi A6/RS6 (incl. AllRoad) - 1998-2004
VW Passat - 1998-2005
This product is SPC 81350 and replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
Old Jan 2, 2014 | 06:01 PM
pa4ul's Avatar
well as for the clunk i would think it might be your cv joints or axle. Have u noticed and black gunk near where the axles are. Might be a torn boot leaking. As for your rubbing you can remove the top screw in the fender and roll the fenders also. That stopped me from rubbing.
Old Mar 12, 2014 | 11:44 AM
ex56TT's Avatar
Banned
i love it, perfect ride height. how is the camber ?
Old Mar 12, 2014 | 02:18 PM
pa4ul's Avatar
im almost stock on camber.
Old Mar 13, 2014 | 03:46 PM
ex56TT's Avatar
Banned
awesome that car is sick !
Old Mar 13, 2014 | 06:32 PM
pa4ul's Avatar
thanks. She is my baby!
Old Apr 29, 2014 | 12:22 PM
ex56TT's Avatar
Banned
yeah that is nice !
duaner
May 14, 2017 08:38 PM
AudiMom1985
Nov 25, 2014 12:24 PM
20021.8t
Dec 29, 2013 06:29 PM
ypcyrl
Dec 13, 2013 09:50 PM
comfort_racing
Feb 28, 2007 12:59 PM
