MPG problems
Old Jun 28, 2008 | 04:36 PM
mrturbo's Avatar
Default MPG problems
Hey all, been reading for a while but first post.
I have a 2004 automatic 1.8T with 71000 miles. For some reason in the past few weeks my gas mileage has gone to ****. I used to average about 21 driving to and from work, and lately its gone down to about 11. At first I thought it was the gas, but I've gone through a few tanks from different places and no difference. Any ideas what it could be? Everything sounds normal and seems to be running fine. I feel like I may have a little less power than usual but I can't tell if its all in my head. The only mod I currently have is magnaflow exhaust, but I have been planning to do injectors, dv, and stage 1+ soon.
Thanks!
kevin
Old Jun 29, 2008 | 08:24 PM
muckdawg24's Avatar
Default RE: MPG problems
maybe a vaccum leak? That is wierd.
Old Jun 30, 2008 | 09:28 AM
audiprotein's Avatar
Or your 02 sensor went pretty bad. Is there a way you can scan your car for the codes???
Old Jun 30, 2008 | 09:43 AM
euro_2nr's Avatar
Spark plugs changed recently?
Old Jun 30, 2008 | 09:05 PM
mrturbo's Avatar
Nope, haven't changed plugs. I guess my best bet is just to take it in, I'll let you guys know what I find out.
kevin
Old Jun 30, 2008 | 09:25 PM
Yeah, spark plugs/coil packs. But usually, coilpacks dont brake for a long time, they tend to brake when u dont expect ))
Old Jun 30, 2008 | 09:42 PM
hardenthefckup's Avatar
you should check your air filter, and tires for proper pressure then plugs and go from there. and last but not least the fuel filter.
Old Jul 1, 2008 | 08:48 PM
mrturbo's Avatar
Hm, I can't get it in until next week. Do you guys think its safe for me to go on a ~500 mile round trip drive this weekend? I'm not really too knowledgeable about this stuff so I'm not really sure how to check on all these things.
Old Jul 2, 2008 | 08:05 AM
wanthema's Avatar
Well I wouldn't if I were you. If you noticed some problems on your car you should use some other means of transportation, because your car isn't an Honda Civic or some s*** that you can step on without replacing it for cheap, so by not risking any more further problems you should rent another car. Also, mrturbo you should check the engine and tranny level dipstick.
Air filter and tire pressure won't kill the HP. If the engine isn't making any big noises it wouldn't be the plugs.
Old Jul 2, 2008 | 08:34 AM
Actaully they can, but by that much.
Anyways, as i have said before, go to AutoZone or something like that and scan your car.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
