newbie with overheating issues
Old Mar 13, 2014 | 09:01 PM
jessb6a4's Avatar
Default newbie with overheating issues
hello ....
ok so i recently bough an 03 a4 with 130,000 miles on it from the original owner whom said they have kept it dealer maintained (never recieved my proof though , lesson learned get everything at that very moment!!)
.. now on to the issue im having
first was coolant flange, replaced that
about a couple days of that being replaced my heat was weak went back got some air out of the lines had it re-bled
now... car would over heat to 3/4 the way and go back down to 1/2
i thought thermostat, my mechanic does not believe so he thinks water pump.. fine i buy all parts was just gnna do the whole damn thing (water pump, timing , thermo, coils and spark plugs (since i was getting a misfire code too) was going to drop it off next week but now tonight the car over heated all the way and didnt go back to 1/2 way point . just wondering if any one had any insight on this i would appreciate it very much
thank you in advance
Old Mar 14, 2014 | 01:11 AM
kjopen's Avatar
Hi and welcome,
Daft question however, is it actually overheating or could it be your gauge? If it isnt actually overheating then I would suspect the coolant sensor in the bottom of the radiator - G83. If it is overheating then what is hot? - hot top hose from radiator, hot heater (check your heater pipes to confirm), hot radiator, electric fans coming to cool down?
The guys on this forum are great - but give a few more clues...
Old Mar 14, 2014 | 04:55 AM
patc's Avatar
Hi and welcome, as above
Old Mar 14, 2014 | 12:11 PM
pa4ul's Avatar
if u havent done your coolant flange them temp sensor on there might have taken a crap on you. . . Thats a very easy thing to replace. Just a tight squeeze for your hands.
Old Mar 14, 2014 | 04:49 PM
jessb6a4's Avatar
coolant flange and temp sensor was replaced i dropped off the car today lets see what happens :/
Old Mar 14, 2014 | 04:56 PM
kjopen's Avatar
Let us know what it was - and if you still have an issue of course ...
jessb6a4
Mar 13, 2014 08:03 PM
BreezeThe TT
Sep 1, 2013 07:59 PM
rekabj1108
Mar 9, 2012 08:16 PM
fireman9585
Aug 7, 2011 03:13 PM
nfast
Jul 7, 2010 07:25 AM
