no power under load, help please
Old Jun 30, 2015 | 10:45 PM
JakeT83's Avatar
Default no power under load, help please
I have poured over threads with similar issues, but none are quite the same or as severe.
The car is SLOW. It takes almost a full minute on flat ground to get up to 60 mph. Uphill it wont go faster than 40mph. It idles fine, but once in gear it wont accelerate for crap. itll rev up to 4,000 rpm or more, but doesnt put any of that power to the wheels.
I had several vacuum leaks that I fixed. I thought that would fix it, but it didnt. It idles smoother now, but still beyond sluggish. The last time I checked, it was throwing underboost code and several misfire codes, but that was before the last vacuum leak was fixed. One of the hoses looks like it is collapsing when idling, but I dont hear any leaks, still think it would run a lot better if it was just a small leak.
I unplugged the MAF sensor to see if would run better and it did not.
coil packs could be the issue, but i dont have much money and dont want to keep throwing darts, and wasting money i dont have.
Have replaced the coolant temp sensor, thermostat not terribly long ago. Any help or advice is appreciated.
Old Jun 30, 2015 | 11:32 PM
sharky2002's Avatar
i have an audi a4 b6 1.8t manual transmision with low power and the scanner says 16486 Mass Air flow sensor signal to low. is it the same on yours ?
Old Jul 2, 2015 | 07:39 AM
JakeT83's Avatar
I don't have that code. Is that from a VAG COM? I don't have access to one of those. Just using universal code reader.
Old Jul 7, 2015 | 04:41 PM
JakeT83's Avatar
Bump...
Jim_Coupe
Feb 18, 2013 04:48 AM
jdahlen24
Jun 29, 2011 02:09 AM
oettinger1919
Jan 8, 2009 08:56 PM
90sMoneypit
Mar 5, 2008 12:38 PM
Dr!ven
Jul 16, 2007 01:37 AM
