Over 85MPH steering wheel shakes?
Old Nov 10, 2009 | 10:54 PM
dpc1192's Avatar
Default Over 85MPH steering wheel shakes?
Do I just need an alignment?
My steering also feels as if it is a little loose, always not just when I'm going very fast.
Thank You
Old Nov 10, 2009 | 11:16 PM
auditech79's Avatar
Have the wheels balanced before anything else, they should also be able to tell you if you have a bad tire. Just make sure to tell them you have a front end shimmy.
Old Nov 10, 2009 | 11:59 PM
Midniteoyl's Avatar
^^ Look at the tires, but have them look at the tie rod ends and control arms too...
Old Nov 11, 2009 | 05:17 AM
Dan1969's Avatar
Get new tires and balance them... Bet that's your problem.
Old Nov 11, 2009 | 04:20 PM
knerml's Avatar
Member
To check to see if it's the tires, just rotate them.
If the shake goes away or changes, it's the tires.
Old Nov 12, 2009 | 01:22 AM
auditech79's Avatar
Thats not good advice. Using your example it could be a wheel out of balance too, rotating the wheels isn't a good way to diagnose a bad tire, putting it on a high speed balancer is the best way to find a seperated bead or bubble in a tire.
Old Nov 14, 2009 | 12:56 PM
dunanga's Avatar
Default Shaking steering after MPH
This could be as simple as over inflated front tyres, check that first before tinkering deeply!
Old Nov 16, 2009 | 02:12 PM
esandes's Avatar
Banned
you could also have a screw or nail inside of the tire causing this. i had a similar problem with my golf. the vibration was noticable more and more and finally the tire popped. with the new tire on, it's perfect. no vibration or noise.
Old Nov 16, 2009 | 08:02 PM
Midniteoyl's Avatar
^^ thats sounds more like a broken belt..
Old Nov 16, 2009 | 11:31 PM
auditech79's Avatar
Probably was a broken belt, that would have to be one BIG *** bolt to cause a vibration. Of course running over a bolt could mess up the belt.
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
jonsaudi
Oct 12, 2007 05:48 PM
A4in808
Apr 28, 2006 12:29 PM
hypnotiks
Mar 14, 2006 02:30 AM
