Problem with signal lights
Hey everyone,
Got a weird problem with my signal lights, mainly the right ones.
After I start driving, the second or third time I use them, it will say my right front signal is out, then the right side one, then the rear one.
Then I go to use them a few more times, they fix themselves.
Primarily this happens with the right ones, but sometimes the left ones too.
Does this sound like the relay is messing up? My friend had to replace his relay, however his went out completely, nothing like what mine are doing.
Thanks
Thanks
Wow forgot I posted this and forgot to update it. Strangely, it turns out it was a bad bulb causing this issue, so I did fix it a while ago.
But now it's happening again in a different way:
https://www.audiforums.com/forum/b6-...orking-179539/
