question about running lean
Old Jan 8, 2009 | 01:49 AM
marcus02390's Avatar
Member
Default question about running lean
First off i have a 02 audi a4 1.8t. I started modding my car by just putting on a 3inch test pipe and a air box mod. My last mod was doing the air box and my dad is telling me that im leaning out the car and im going to blow it. Is this true or not.
Old Jan 8, 2009 | 12:22 PM
Myst420's Avatar
Are you getting any codes? If not, I doubt you're running lean. Exactly what air box mod did you do on a b6? As far as the test pipe goes, do you have an exhaust to go with it?
Old Jan 8, 2009 | 01:31 PM
Member
The only code i know i have is a catalytic converter. I did the air box exactly like this on the audizine website. http://www.audizine.com/forum/showthread.php?t=168510
My test pipe is just hooked up with the stock exhaust and plan on sticking with that because their exhaust system are a little expensive.
Old Jan 8, 2009 | 01:33 PM
Member
I know the air box mod is not consider for better gains i just did it for the sound.
Old Jan 8, 2009 | 05:07 PM
kwik_shift's Avatar
Marcus,
You'll be fine, don't worry about it. Your dad is just jealous. LOL Like you mentioned about, the cel is on because you removed the catalytic converter. APR and other companies have chips(ecu flash) with high flow cat files which eliminates the cel. There are also 02 foulers that are "supposed" to make the cel go away. Works for some, doesn't for others.
Old Jan 8, 2009 | 05:16 PM
Member
Thanks kwik shift i knew why the cel was on i just had the chance to delete it. LOL im the one who should be jealous because he has a 600+hp rx7
Old Jan 8, 2009 | 07:44 PM
shane.trammell's Avatar
But you can't do much with 600hp in an rx-7 unless it's tubbed bc you won't have any traction!
Old Jan 8, 2009 | 08:05 PM
Member
it would have no traction in 1st through 3rd but 4th and 5th it had traction, it wasnt insane loss of traction though rotary motors dont produce allot of torque.
Old Jan 9, 2009 | 07:33 PM
audiprotein's Avatar
you can be running lean without a CEL, BUT that would be a minor problem... When your ECU receives bad lean signals, you get a CEL.
And yes, running very lean can damage your engine.
Vezon
Dec 27, 2012 04:39 PM
MAT123
Nov 2, 2010 10:31 PM
mandito219
Aug 9, 2009 11:16 PM
auditt225
Jun 25, 2007 03:44 PM
Anos
Mar 30, 2007 07:31 PM
