random overheating and ac failure
Old Oct 15, 2014 | 12:33 AM
robertogp0987's Avatar
Default random overheating and ac failure
i just got a lil desperate and im new to audis id really appreciate you're help. i drive a 2005 a4 cabriolet convertible 1.8t. 2 days ago the ac started to blow hot air then rarely while driving kinda cold air that was 2 days ago. Now after doing the oil change which was due, the car started over heating occasionally on idle but not always. the fluid sign turns on and the temp gage goes all the way to hot but when i open the hood everything seems normal, so i turn the car off 1 minute turn it back on and the temperature is restored to normal and i can drive around. so i have no idea what the problem could be i think i read all the possible post and havent found something thank you for you're time.
Old Oct 15, 2014 | 01:26 AM
r6forfun2008's Avatar
[QUOTE=robertogp0987;1481569]i just got a lil desperate and im new to audis id really appreciate you're help. i drive a 2005 a4 cabriolet convertible 1.8t. 2 days ago the ac started to blow hot air then rarely while driving kinda cold air that was 2 days ago. Now after doing the oil change which was due, the car started over heating occasionally on idle but not always. the fluid sign turns on and the temp gage goes all the way to hot but when i open the hood everything seems normal, so i turn the car off 1 minute turn it back on and the temperature is restored to normal and i can drive around. so i have no idea what the problem could be i think i read all the possible post and havent found something thank you for you're time.
First check if your small coolant fan is coming on when the temperature gauge climbs. If small coolant fan is coming on then next thing is check if any fault codes in ecm. If there's a fault code in ecm for coolant system then please post then could give you what to check.
Old Oct 15, 2014 | 03:05 PM
ok thank you r6forfun2008 thats what im doing right now, ill keep you posted
Old Oct 16, 2014 | 08:17 AM
Ok let me know. We can go from there.
robeggert90
Apr 28, 2015 12:09 AM
zombiekiller0331
Jul 15, 2013 09:46 PM
Kabendawggg
Jan 14, 2013 02:51 PM
rupert
Nov 2, 2007 10:54 AM
