REALLY LOUD FAN NOISE AFTER STARTING?!?!
Subscribe
Jun 17, 2019 | 11:23 PM
  #21
Hi CincyTT, Mine comes on at first startup and goes out well before the engine is at temp. And this just started in the last two weeks. never did it before for the 4 years previous I owned the car. I do not think this is the answer. Kev
Reply
Jun 17, 2019 | 11:26 PM
  #22
Quote: I got the same problem, but it only happens on cold temps. very cold []
No mine does it either in cold weather or a nice warm day. For 4 yeasr it never did this and just the last two weeks it started. That does not correlate with "its normal".
Reply
Jun 17, 2019 | 11:27 PM
  #23
Quote: You dont have a problem. Its normal. Its there to warm the car up
No sorry i do not think this is the answer. My car never ever did this regardless of cold weather minus 20 degrees or hot weather 32 degrees. It started doing it out of the blue just 2 weeks ago. before that never for 4 years.
Its something else.
Reply
Jun 17, 2019 | 11:30 PM
  #24
Quote: For all these issues is common problems and solutions. The temperature gauge is malfunctioning because of a bad Temperature sensor, like 20 bucks if you get it from VW the dealer. The Coolant flange goes bad every now and then, you have to replace the little nipple, I think there's a PDF attached to a thread floating around with a break down for those with a 3.0. The fan noise, if the car is heating then the fan will come on, if it's not then you probably have a bad fan control thingy, have to replace it, don't know the price. Here's a link to the Common Probl and solutions: https://www.audiforums.com/forum/sho...d.php?t=128740
What is the most obvious telltale sign that the Temperature gauge may be malfunctioning? Are we going to see the temp gauge hop up to hot at startup and then drop back down or what will we notice to determine that?
Reply
Jul 11, 2019 | 12:05 PM
  #25
UPDATE...... I found the problem of what was making the Loud supersonic fan noise on cold start each time I started the car when it was sitting for a long while (ie: overnight). Looking at the front of the car way down in the lower left corner, I pulled the lower engine gaurd panel (the large black plastic piece that shrouds the lower engine) and I found a 1.5" (I think) diameter hose with that flexed ribbed contour that came to a 90 degree elbow. It was unplugged from the box or compartment it was supposed to plug into. I plugged it back in and the loud fan whirring noise disappeared.
Reply
Jul 7, 2024 | 02:06 PM
  #26
When that's happened to me, its been the coolant temperature sender. Bet you throw a CEL in a few days, if so, it almost certainly is. Luckily its an easy fix...
Reply
Subscribe
