Rear rotor replacment ?
Old Jul 24, 2013 | 11:28 PM
roxxx's Avatar
Default Rear rotor replacment ?
I was wondering if there is a DIY for the rear rotors I cannot find proper size wrench to take the carrier off to change the rotor
Old Jul 25, 2013 | 07:05 AM
tofast2belast's Avatar
it is a 8mm hex key socket for the carrier like an allen key but use a socket one.
Old Jul 25, 2013 | 02:08 PM
roxxx's Avatar
Thank you
Old Jul 26, 2013 | 03:03 PM
roxxx's Avatar
Ha turns out someone has already stripped the hex bolt already now the fun begins
Old Jul 26, 2013 | 11:23 PM
Nebuchadnezzar's Avatar
I highly recommend the following:
Irwin Industrial Tool 53227 Hex Head Multi-Spline Extractor Set, 25-Piece - Amazon.com Irwin Industrial Tool 53227 Hex Head Multi-Spline Extractor Set, 25-Piece - Amazon.com
I was able to get a fill plug unstuck with this set. I must have applied well over 100 foot pounds to get it off and the extractors took it. Obviously, you need nice even pressure to get the job done. That set was worth every penny.
Old Jul 27, 2013 | 08:10 AM
dam lol if only i found this earlier.. i could get the bottom bolt out on the rear passenger but the top was stripped out... i ended up prying the carrier so it rotated out enough to slip the rotor out.
Old Jul 27, 2013 | 11:51 AM
roxxx's Avatar
Thumbs up
Thank you
Q7Barry
Audi Q7
Aug 15, 2012 11:13 PM
twenty8red
Jun 4, 2009 10:33 AM
71455olds
Mar 4, 2008 01:04 AM
khaugland
Apr 4, 2007 03:03 PM
mad_circle21
Oct 2, 2006 11:48 PM
