rough idle and car turns off!
Old Dec 18, 2013 | 05:26 PM
deherrera21's Avatar
Default rough idle and car turns off!
I changed my timing belt over a year ago and 2 months after i ran into a vacuum leak that took quite a bit to find. i made the mistake of driving the car like that for a few months before really digging deep to find all the leaks. after fixing all the apparent leaks ( using a cigar to blow smoke in the system) i still have the rough idle, although not as rough as it was before. i went to autozone and cleared the codes waited for them to trigger again then pulled them and i got p0300,p0301,p0304,p0302,p0303,p0722. the biggest issue is that when i stop and the car down shifts to 1st gear the rpm drops really low and sometimes just causes the car to turn off!!!
Old Dec 18, 2013 | 06:09 PM
pa4ul's Avatar
you have a 1.8 or a 3.0 Might check your coil packs or spark plugs.
Old Dec 18, 2013 | 08:59 PM
it is a 1.8t and would they all go out at the same time?
Old Dec 19, 2013 | 01:01 PM
pa4ul's Avatar
it could happen. But odds are its one going bad that is causing problems downstream. But its a fairly inexpensive part and u can diy swap in all of about 20 minutes.
IAFF2938
B7 Models
17
Dec 21, 2015 11:14 PM
justinclarke
Nov 25, 2010 04:03 PM
devon75
Sep 12, 2008 03:40 PM
specialK4
Jul 27, 2006 03:19 PM
