Rough Vibrations from Idle
Old Oct 30, 2008 | 12:10 PM
ee99ee's Avatar
Default Rough Vibrations from Idle
I have a 2002 Audi A4 1.8T FWD CVT with 101000 miles. I have noticed over the past 10,000 miles that the idle has been causing more and more vibrations. The car isn't idling rough, but it is vierating more from idle. Once it's above 1200 RPM or so, there are no problems.
Time for new motor mount? What could cause this?
-Chris
Old Oct 30, 2008 | 03:09 PM
audiprotein's Avatar
Open your hood, look carefully if u seen ANY unusual color fluid around your mounts.
When your trans shifts, do u feel any vibrations?
Also, try to look at your snub mount- it might be cracked.
Old Oct 30, 2008 | 08:30 PM
shelbyturbo's Avatar
i've got a worn motor mount and feel the same vibration...when i put the car in neutral the vibration goes away. i've also got a pretty messed up looking check valve. i'm changing the vavle tomorrow and probably try and do the mounts within the next couple weeks. i'll let you know if either make a difference.
Old Oct 30, 2008 | 10:51 PM
silveraudib6's Avatar
are motor mounts expensive to replace? cuz my car does the same thing
Old Oct 31, 2008 | 12:09 AM
ee99ee's Avatar
Good catch... snub mount cracked. Holy crap that doesn't look easy to replace... hmm... Time to find a DIY article.
-Chris
Old Oct 31, 2008 | 01:56 AM
-Chris
Easier than you would think )) Even the DIY might look hard from the pics, but all u have to do is to put your car on jacks, unbolt the bolts, put the new snub in, start your car. let it idle for 30 seconds (you might rev it up just a bit) so the new snub gets in good "position" tighten all the bolts.
http://www.goapr.com/Audi/support/b6_snub_mount.pdf
Old Oct 31, 2008 | 08:35 PM
wow that actually does look pretty east from their instructions...how about the motor mounts, are they a little more difficult?
Old Oct 31, 2008 | 09:18 PM
A bit harder cause you will need to lift your engine up a bit to get the old mounts out and put the new ones.
Here is DIY http://www.audizine.com/forum/showth...ine+mounts+diy
Read post #3 for the MUCH EASIER instructions.
IAFF2938
B7 Models
17
Dec 21, 2015 11:14 PM
justinclarke
Nov 25, 2010 04:03 PM
riggs5
May 28, 2010 06:42 AM
Veegard
Oct 6, 2009 05:49 PM
