ruff idle
Old May 5, 2009 | 11:37 PM
riggs5's Avatar
Cool ruff idle
My A4 3.0 has a bit of a ruff idle when I come to a stop. The idle comes back up and runs smooth until the next stop. Last month I replaced 4 coil packs and 6 new plugs. I got better millage but the ruff idle is still there. I have read other comments about coil packs or a vacuum leak. Last year I installed the Hyperflow intake, which is a K/N type air filter. I seemed to notice this issue after I installed it but was not sure if I had the problem all the time. I did check to see if the original air box had a vacuum assist that would need to be plugged but no luck.
Any suggestions what I might look for? Should I carry a few coil pack in my trunk?
Old May 5, 2009 | 11:40 PM
Dylan19's Avatar
i keep spare coil packs in my trunk. 8 actually. i have 4 hitachi e's and 4 of the standard ones that you get from audi
Old May 6, 2009 | 07:13 AM
Pablo_Ottawa's Avatar
Things to check:
Dirty MAF
Clogged fuel filter
Dirty throttle body
Check the air filter and breather system for any obstructions
Faulty sensor SOMEWHERE. Audis have tons of them
Run a scan and see what faults come up
Old May 6, 2009 | 07:27 PM
audiprotein's Avatar
and a cracked snub mount
wshymas
Jan 22, 2014 09:07 AM
meta4
Sep 4, 2007 10:59 AM
idigaudi
Oct 5, 2006 03:03 PM
idigaudi
Oct 1, 2006 07:52 PM
idigaudi
Sep 30, 2006 07:08 PM
