Stereo Issue
Hey Audi gang out there! Just wondering if anyone has had this issue and what was the fix. My rear passenger door speakers have gone out and the rear drivers door goes in and out if i turn it up load. could this be the amp pr the head unit itself? i spoke to the dealer and they told me to pull out the head unit and check the connections in back. Did that but useless, problem still there. Happen to anyone else out there??
Thanks!
Thanks!
it is most likely an issue with the stock amp. Depending on what car/stereo you have......(plz post this).... the stock amp on a concert, non-bose, system is located behind the carpeting in the trunk on the passenger's side. Removing the back seats is necessary to remove the carpeting to check it out.
Yeah that's right you did have this same problem! You ended up taking your seat out or not?
